Coil pack fitment/application/info thread
Old Feb 24, 2026 | 12:27 PM
  #141
windhund116's Avatar
Originally Posted by cosmomiller
So are the ones for 2008/9. I just ordered 4 from Japan at $140 each.
If you could post photos of your present coils and the ones you are getting from Japan, that would be really groovy!
Old Feb 24, 2026 | 01:48 PM
  #142
9KCanuck's Avatar
Originally Posted by engifineer
Parts pricing is getting crazy. Injectors are about $300 each for our car. Glad all mine tested well after cleaning!
What makes the 04-05 coil cheap is that it is shared with other cars. Element, CRV, Civic, Accord. While the 00-03 original part number and the 06+ are S2k only.
You're exactly right, and the fitment exclusivity theory definitely makes sense. It must simply be that there are so few of those ones out there now (assuming Denso no longer bothers producing those ones, or just VERY few), so supply and demand is in full effect.
Here's the fitment info for each:
Denso product pages:
673-2300 '00-'03 -- https://www.densoproducts.com/denso-...-ignition-coil (Discontinued)
673-2301 '04-'05 -- https://www.densoproducts.com/denso-...-ignition-coil
673-2304 '06-'08 -- https://www.densoproducts.com/denso-...-ignition-coil
Rock Auto for fun:
673-2301 -- https://www.rockauto.com/en/moreinfo...&pt=7060&jsn=3
Old Feb 25, 2026 | 09:38 AM
  #143
cosmomiller's Avatar
Top Answer: 1
Will do. The current pictures of my coils (original to the car-never replaced) are above. It is going to take at least a month for shipping as I don't need them right away and received an $80 discount in return from the company.
Mr Matchbox gave me the recommendations for this site (I have used other ones in Japan with good results) and he affirms it is a good company that has a stellar reputation. The reps assured me I am getting OEM Honda labeled parts, brand new. Here is the invoice.
The total of Yen 133,551 equals $858. I paid with a credit card in Yen to avoid bad exchange rates using dollars or PayPal. The Coils are Yen 22,355 which equates to $143.64.
Shipping with DHL is $53 but there is no sales tax which would have been $73 so I am ahead there.
1 JPY = .00643 USD
Old Feb 25, 2026 | 10:07 AM
  #144
Looks like you are R&Ring your clutch, too? Good luck with both!
Old Feb 25, 2026 | 12:17 PM
  #145
Jah2000's Avatar
Don't forget tariffs... I bought and just received an audio mixer from the UK just a few days ago via DHL, and the tariff was dang high at 35% (tariff / item cost) + $17 broker/admin/disbursement fee.
I know UK tariff are supposed to be 10-15%... so idk why they tacked on more tariffs (probably parts/components used in it from China, irdk).
Also got slapped with a tariff for a cheap $5 (+$18 shipping) vinyl record from Japan. Media/informational/educational material are supposed to be exempt; but FedEx still added/slapped on an extra tariff code on top of the clearly duty-free tariff code on the invoice (which is illegal). Cheap tariff $1.05, but the broker fee is $17, making this record too expensive. I disputed it, despite their scare-tactics and extortion attempts of "may receive a $90-150 fee if we are not the cause."
Old Feb 25, 2026 | 12:36 PM
  #146
Top Answer: 1
I have all the other stuff, I just needed those so I thought I might as well combine. My flywheel should be fine.
Old Feb 25, 2026 | 09:13 PM
  #147
You'll love the new clutch! Lighter feel, more positive friction point.
Old Feb 26, 2026 | 05:43 AM
  #148
Mr.Matchbox's Avatar
Originally Posted by 9KCanuck
I tested my 4 original coils and the 1 new one with a multimeter.
With the meter set to 2000Ω, I got a reading for each old coil (in no particular order) at 1190, 1190, 1194, 1195. <shrug> They are probably completely fine, seeing as not one of them measured significantly higher.
What's interesting is that the NEW coil measured 1070. Which I guess means less resistance, and therefore bigger spark, and therefore I just modded one of my cylinders? Sweet.
So... I had German Brand Herth+Buss Ignition coil with 1 rib, wich meassured around 1280 Ohm. (Herth + Buss are -THE- really trustworthy Aftermarkekt company for Japanese cars here in Germany.)
The NGK Nr. U 5099 wich are sold here in Europe have two Ribs = Looks exactly like the 06-09 Modells and meassure 980 Ohm. According to NGK europe Parts catalouge the fit all Modells of S2000. I hav asked NGK about the differences. Lets see if they Answer.
Old Feb 26, 2026 | 06:24 AM
  #149
Car Analogy's Avatar
So maybe, per my lengthy speculation post, Honda indeed added resistance to 06-09 coils, for rfi interference with XM radio (and changed them for all markets, even if no XM, just so same parts everywhere).
Maybe, as part of that, they went from 980 ohms to 1250. So that would mean using newer 1250 coils on older cars = weaker, bad idea. But old coils newer cars, nbd if you don't have XM.
So maybe NGK knows this, so to keep their costs down, they just make coils per the older 980 spec, and say they work on all S. That will work perfectly in marketd that don't have XM. In markets that do, still fine except if car actually has XM, but since so rare, not something they care about enough to make coils with 1250 resistors.
Old Feb 26, 2026 | 07:45 AM
  #150
Slowcrash_101's Avatar
What's bad about higher resistance coils?
