Cold (choke) idle question
Old Dec 9, 2007 | 09:42 AM
JonDeane's Avatar
Default Cold (choke) idle question
I have a brand-new MY07 S2K, and in my opinion the idle speed on a cold start is too high. This is my first S2K, so I don't know if they all do it (which is why I am asking you knowledgeable gurus here )
My beast idles at 2100RPM from a cold start which I feel is excessive - a more comfortable speed would be in the region of 1100 - 1300RPM. My other Hondas (MY07 Accord Euro and MY06 FR-V) don't do this, and indeed idle at a sane RPM when ice-cold.
Maybe it's only the performance Hondas that do this - I used to own a 2.2VTiR Prelude that used to bug me in the same way. I belong to the old school that holds that you REALLY nurse that engine when it is cold (I don't exceed 2000RPM until I have a reasonable (water) temperature reading, and then I don't exceed 3500RPM until 5 minutes after that point - when the oil temp has had a chance to stabilise). Then, and only then, do I thrash it if I have to.
If I approach my dealer with this question, I KNOW I am going to get fobbed off - and nothing will happen. What I would like to know is if this fast-idle / choke setting can be programmed / altered somewhere in engine management? I'd like to take it into the dealer, and say 'Do X, Y and Z' and know that I am speaking from a position of knowledge.
Thanks in advance!
Jon
Old Dec 9, 2007 | 03:06 PM
J'sS2K's Avatar
Cold idle at 2100RPM is normal. Give it like 3 or 5 mins it'll drop to 900RPM.
Old Dec 9, 2007 | 04:42 PM
8 GRAND's Avatar
They idle high to begin with IMO.
Chad
Old Dec 9, 2007 | 11:07 PM
The Twanksta's Avatar
mine is exactly the same, its perfectly normal. Honda wouldnt have made it do it if it werent right...no worries!
Old Dec 10, 2007 | 01:50 AM
minimebang's Avatar
Thanks in advance!
Jon
if u shift before 1900 RPM, ur actually bogging the engine. This is not the way to drive the S. No matter if it is a cold start, shift at 3500-4000 will be good enough. When ever the car got started, that means the oil has lubricate all the internals already. Then why u should still concern about the RPM? just dont hit VTEC is ok. Theres no point to shift that low and bog the engine.
Old Dec 10, 2007 | 08:31 AM
I agree, i just tried the whole shift low for gas mileage...ran upon the MPG thread someone said to try shifting at 3500-4000, so now i shift at 4k, i go places faster, and i get BETTER mileage! roughly 23 with both highway/city/vtec. Good enough for me
I do however tend to shift a bit lower for the intitial 4 minutes or so for eveything to warm up nicely before getting on it or anything.
Matt Holley
May 9, 2015 09:06 AM
GaryB
Dec 13, 2010 10:19 AM
JamieP
Aug 13, 2010 10:28 AM
jmd2000
Oct 27, 2008 08:59 AM
yhaneef
Aug 28, 2008 01:41 AM
