this is crazy
I'm having the same issue, I brought my car into the dealership to have the oil changed and the front brake pads replaced and when I got it back it pulls to the right when accelerating and back to the left when I let go of the gas. Before I brought it in, it sounded like my diff. was making a grinding noise and now after I got it back it doesn't at all anymore, which is nice but now it's pulling...I'll take it back tomorrow and see what they say.
Most likely reasons this could happen:
1.) Tires worn unevenly.
2.) Brakes hanging up
3.) Tires of different tread construction or tread depth
4.) Coilover install done wrong. Did you get an alignment AFTER installing the coilovers?
5.) Worn bushings. Did you clock your bushings?
The tires are probably the most likely culprit. Try changing them from side to side. It doesn't matter if they're directional. Just do it temporarily to check.
Do the tires have any uneven wear? Is one side worn more than the other? Was your alignment done correctly? Do you have a print out?
Originally Posted by tinkfist,Aug 30 2008, 02:45 PM
I was thinking this as well. Check to see if a brake caliper is seized or brakes are dragging anywhere.
