Cruise Control does not work
Hope this is the right section.
The cruise control does not work on my 2000 with 43K miles. I've had the car for a week and everything on the car works perfectly, besides the CC. Yeah, I missed this when I bought the car. The CC activates fine (button not on the steering wheel). When I press the set button on the wheel under 25mph, nothing happens - good. When I press the set button over 25mph, the light on the dash comes on but the car does not "cruise" or maintain speed. I haven't the slightly idea why. The car does have aftermarket speakers, but the same headunit. Any ideas or help you can give me would be great. Thanks.
I don't know what the exact specs from Honda are but generally speaking, cruise controls aren't designed to work at speeds much below 35 mph or so. That is doesn't work at 25 mph is probably normal.
Does it work between 45 and 70 mph?
Drive Safe,
Steve R.
Sorry, reread the post and you answered that. At least the over 25 part. How much over 25 have you tried it?
The thottle on the engine has two cables running to it. One is from the foot peddle and the other is from the cruise control servo. Just follow it back and you'll find it. Might be something as simple as a loose connection.
Good luck!
Drive Safe,
Steve R.
Originally Posted by Indiana Jones Posted on Jan 4 2006, 09:46 PM
Where is the cable and accuator located? I'm not very mechanically inclined, but I'm going to try and find it.
Good luck!
Throttle only has one cable. The CC servo connects directly to the gas pedal.
The black box right behind the coolant overflow tank is the CC unit
Just remove the cover and check the cable.
Drive Safe,
Steve R.
