Diagnosing a misfire
Old Apr 1, 2019 | 08:16 AM
o'malley_808's Avatar
Default Diagnosing a misfire
Trying to chase down a misifre at idle. No codes, runs smooth everywhere else. You can hear it miss and sputter out the exhaust.
AP2 engine on AP1 ecu.
Tried map whack. Checked plugs. Only other things I think are next is coil packs and injectors but I don't have any spares to swap with. Anything else I can start testing/trying?
Old Apr 1, 2019 | 08:28 AM
Say Chi Sin Lo's Avatar
I have a set of spare AP1 coilpacks that I replaced. PM me if you want it?
Old Apr 1, 2019 | 09:21 AM
outeiroj's Avatar
Unplug one coil at a time and you’ll notice which one doesn’t get drastically worse
Old Apr 1, 2019 | 09:30 AM
afzan's Avatar
I had a similar 'issue' -- it only happened at idle..
I replaced pretty much everything (valve adjust, leakdown was good, replaced coils/plugs/MAP/TPS, got injectors cleaned) and then gave up.. I eventually got an EMS, ID1050x and a SC and problem is gone so I think it was either injectors or ECU
btw I think I actually got the MAP sensor from you via pizza boy
Old Apr 1, 2019 | 10:37 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
-Misfire at idle/all other areas are ok
Valve adjustment is the first step.
Old Apr 1, 2019 | 10:46 AM
Thanks I'll let you know.
Yeah I've heard of this test and doing the same with the injectors. I'm leaning towards leaky injectors after reading a bunch of reports of the same issue.
I think your issue was the injectors since coilpacks didn't solve the issue. Been reading a bunch of reports of people with similar issues and having leaky injectors. Cleaning them won't resolve it as some believe the spring in the injector goes weak.
Yeah definitely going to do that on this "new to me" car. I'm going to check the fuel trims tonight with my OBDll scanner also as I've heard you can sometimes spot an injector issue from the O2 reading being rich and STFT.
Chitoki
May 18, 2016 05:09 PM
Si2k
Oct 12, 2014 01:49 PM
2d-ink
Feb 15, 2014 08:00 PM
jdmfreak333
Mar 26, 2010 10:59 PM
Downgear
Sep 11, 2009 08:21 AM
