Dome Light problems
Old Jul 28, 2010 | 09:12 PM
DISCONTD's Avatar
Default Dome Light problems
ok this will sound bizarre but today i was cruising at about 70kph and had to turn, which i took the corner at decent speed 40-50, and the dome light flicks on in the middle of the turn.
heres the crazier part.
country road, decide to let the engine come alive. once i hit vtec the dome light flicks on yet again. i couldnt believe it at first so i tried it again and same thing happened.
not sure if my car is alive or there is a connection problem. has anyone else had this problem before?
Old Jul 29, 2010 | 03:42 AM
Kaneda215's Avatar
Never had the problem before, but it could be when your car vibrates with a certain resonance due to your engine/exhaust combination (you may not be stock)... you could be shorting two connects together that would normally be an open. Therefore whenever, whatever vibrates, it shorts wires together thus causing the light.
Who knows tho
Old Jul 31, 2010 | 04:57 PM
dhayner's Avatar
Check the door switches.
paS2K
May 6, 2012 11:03 AM
ryce4u
Aug 9, 2010 01:25 PM
shakes
May 7, 2010 04:38 PM
mr flannery77
Apr 17, 2010 08:03 PM
rayman1031
Apr 26, 2009 06:21 AM
