Electric Steering problem, help!
Old Nov 11, 2009 | 02:53 PM
s2000 rBED's Avatar
Default Electric Steering problem, help!
I've just bought a cheap s2000 for a weekend/track car. The electric steering wasn't working when i bought it and was told by the previous owner that it just stopped working a few months ago and he hasn't got the time or money to fix it so he wants the car gone.
He said it might need a new steering rack so i bought a second hand steering rack off a breakers yard and had it fitted but the electric steering still isn't working??? i then changed the EPS box under the bonnet as i was told that might be the problem but still nothing.
Can anybody please tell me if there is anything else that might need changing or checking. i am really confused and can't seem to put my finger on what's wrong with the EPS system. also where is diagnostic port located on the s2000 as i can't find it???
Please help, your advice will be appreciated....
Old Nov 11, 2009 | 05:55 PM
zeroptzero's Avatar
diagnostic port is on the driver side under dash close to center console, I think it is a white coloured trapezoid shape connector. Check the fuses ?
Old Nov 12, 2009 | 02:26 AM
s2000 rBED's Avatar
Thanks for that mate, i'll have a look. i've checked all fuses....
Old Nov 13, 2009 | 02:50 AM
s2000 rBED's Avatar
any ideas, guys???
Old Nov 13, 2009 | 04:54 AM
Olegator's Avatar
pull up wiring diagram and start checking....
actuate the motor, to see if it works,
then check wires for continuity
check the relay...
Old Nov 13, 2009 | 06:54 AM
spets's Avatar
Is the EPS light on?
Once you find the diagnostic port (might be under the pax side of the dash since you have a 2000), short pins 9 (brown wire) and 4 (ground) and the light should blink in sequence long blink is a 10, short blink is a 1. <long><long> <short><short><short> = 23.
then you need to find out what each code means... a factory service manual would help. In the meantime click on the two links below:
http://img.photobucket.com/albums/v298/spets/eps1.jpg
http://img.photobucket.com/albums/v298/spets/eps2.jpg
Old Nov 13, 2009 | 07:39 AM
Stratocaster's Avatar
On the 2000 year cars, here in the US, the diags port was on the passenger side of the car, under the dash. So for you with a RHD car, it could have been on the drivers side.
Old Nov 13, 2009 | 07:56 AM
s2000 rBED's Avatar
i'll have a go, thanks for the help
S2KFAN27
Sep 11, 2016 09:17 AM
WashabiS2K
Oct 20, 2009 06:03 AM
awkwardturtle
Sep 7, 2009 08:44 PM
vazelos2k
Jan 7, 2007 10:00 AM
