Engine light Came On
Old Jan 24, 2004 | 10:42 AM
Grazhoppa's Avatar
Default Engine light Came On
Need help in getting rid of this light. It came on expectedly last night.
No mod and only have 18k. I just recently changed oil and oil level and well as water are in range. Any suggestions? Is it related to the oxygen sensor and covered under warranty?
Old Jan 24, 2004 | 11:22 AM
Road Rage's Avatar
Bought gas lately? You probably forgot to tighten the fuel tank cap. Pull the ECM fuse to reset it, and see if symptoms persist. If they do, dump the code. Search on CEL for plenty of info.
Old Jan 24, 2004 | 03:59 PM
Grazhoppa's Avatar
ECM fuse =??
Dump the code = ??
CEL = ??
Old Jan 24, 2004 | 05:18 PM
wortham's Avatar
cel - check engine light
ecu fuse - if you look on the left side of your driver's side, you'll see a fuse box. to reset the ecu fuse, pull out the fuse in the 3rd slot on the right. that's 3rd slot, not 3rd fuse.
before you reset, however, check yoru gas cap. if it is, in fact, tight, head to autozone and ask them to pull the codes. they'll do it for free. it'll help us here give you an idea of what went wrong.
if i remember ... if the CEL flashes, THEN you're in serious trouble since that's a major error. if it's not flashing and if it sounds fine, a short drive shouldn't make things worse.
Old Jan 24, 2004 | 07:15 PM
Road Rage's Avatar
[QUOTE]Originally posted by Grazhoppa
Old Jan 24, 2004 | 07:29 PM
wortham's Avatar
yep. the search function on the board here rules. just try a few keywords. if those don't work out, try some others or add some to narrow.
Old Jan 24, 2004 | 08:21 PM
Grazhoppa's Avatar
[QUOTE]Originally posted by Road Rage
Old Jan 24, 2004 | 08:41 PM
Grazhoppa's Avatar
Roadrage:
Thanx for the tip and indeed my gas cap was loose.
Wortham:
Thanx for the solution and the light is now off.
johnquester2000
19
Nov 1, 2008 01:35 AM
Al'sS2k
Aug 29, 2006 07:56 PM
Rawhide
Oct 8, 2005 11:11 AM
news2kroller
Jul 13, 2004 10:06 AM
hyperpm
Dec 6, 2003 05:45 PM
