EPS Light
Old May 11, 2006 | 10:53 PM
batikan's Avatar
Default EPS Light
Today, all of a sudden, my EPS light came on and the steering wheel became a lot heavier. We recently installed an eManage on the car. would it cause the problem??
Also right after we installed the eManage, the speedo stopped. it shows the rev and everything but the speed stays at 0 and the mileage stopped. it doesn't increase. is something unplugged? where should I check??
Old May 12, 2006 | 04:35 AM
xviper's Avatar
If there is no speed signal and an rpm above 3000 rpm for more than 3 minutes, the EPS has a brain fart. You've buggered up something in your eManage install. What that might be, only you can find out.
Old May 12, 2006 | 05:19 AM
batikan's Avatar
so if i hook the speed thing back in, the eps light will be gone too???
Old May 12, 2006 | 06:39 AM
Wisconsin S2k's Avatar
You need to figure out where your install went wrong.
Old May 12, 2006 | 08:51 AM
batikan's Avatar
i have the boomslang pnp. i just plugged it in. do you think my yellow box is unplugged?
Old May 12, 2006 | 09:03 AM
do you have a CEL? emanage doesn't replace the ECU i believe, so you should still have your factory ECU. this means, you should have a CEL. if you do, we need the code.
otherwise, we are just guessing, and there's a million things that could cause this. who knows what wires where, etc. any answers we give are an excersize in futility.
Old May 13, 2006 | 04:21 PM
xviper's Avatar
Here is the answer you are looking for. Your Yellow Box needs to be wired up as follows or you will not get a speed signal to the ECU:
Old May 13, 2006 | 05:37 PM
batikan's Avatar
problem solved. thanks...
s2konroids
Mar 28, 2011 05:01 AM
DBXFX
Nov 16, 2010 03:03 PM
fireball
Aug 26, 2010 03:28 PM
ali3nation
Aug 6, 2004 08:20 AM
Reignman
Jul 28, 2003 01:02 PM
