GM SYNCHROS TRANNY FLUID
Old Mar 4, 2005 | 10:11 PM
TwistedS2k's Avatar
Default GM SYNCHROS TRANNY FLUID
it's not as smooth as I hoped it would be. I am going back to mobil MTF on the next change
Old Mar 4, 2005 | 10:13 PM
oakfloor's Avatar
have you tried redline MTL or mt-90?
Old Mar 4, 2005 | 10:16 PM
TwistedS2k's Avatar
i don't know if that will worth my time and $$
Old Mar 4, 2005 | 10:26 PM
oakfloor's Avatar
Its worth the $ to me for a smoother shiftting gearbox. and its a good product. I will never go back to the honda oil, thats for sure. I will try the GMSMFM at the next service. good luck
Old Mar 5, 2005 | 12:57 AM
S2K_408's Avatar
Hmm hopefully you guys can help me. I just did the tranny change w/ the GMSMFM and shifting from 1 to 2nd grinds from time to time. What can I do? I try to shift slowly into each gear, and sometimes it even grinds. I have a 03' and right now its at 15,800 miles.
Old Mar 5, 2005 | 02:47 AM
S2KPUDDYDAD's Avatar
It's the nature of the beast I find that if you double Clutch...that is press once to get out of gear and press agin to go in to gear it helps a lot. I think the 04/05 transmission with there carbon fiber synchronizers do not have as much problem with this. I test drove an 03 before I bought the 02 I have and it had only 2700 miles on the clock and it grinded like a S.O.B.
Old Mar 5, 2005 | 12:35 PM
Utah S2K's Avatar
Check your clutch pedal adjustment.........
Utah
Old Mar 7, 2005 | 07:07 PM
S2K_408's Avatar
Utah
Will do, but I always make sure my clutch is all the way in before shifting. Gets annoying sometimes.
Old Mar 7, 2005 | 07:17 PM
Warren J. Dew's Avatar
We still get the 1-2 grind when the transmission is cold. Waiting doesn't seem to help - I've coasted for half a block and still gotten the grind. Double clutching does fix it, but is a bit of a pain.
acn684
Jun 11, 2012 09:08 AM
LDfavoriteson
28
Aug 17, 2009 11:09 AM
CourageOO7
Jun 24, 2006 07:36 AM
tesseract
Mar 27, 2004 02:37 PM
MarkS2K
Oct 2, 2002 03:57 AM
