Hard to get into reverse.
Old May 6, 2009 | 12:06 AM
badboy00z's Avatar
Default Hard to get into reverse.
I don't have any problems getting into any of the forward gears but it's really difficult for me to get into reverse. I know you're suppose to push vertically down and then put it into gear. My problem is that the shifter feels like it doesn't go down at all. It takes a few tries and engaging/ disengaging the clutch for it to go in. And even then it feels like it will pop out of gear.
I read some older threads and found similar cases but I know it's not on all cars because my friends car and an AP2 that I drove doesn't have this problem. There doesn't seem to be a solution to this problem from the threads that I read. Do I just need to get a new shifter??
Old May 6, 2009 | 05:55 AM
negcamber's Avatar
There is a plastic bushing at the base of the shifter. It may be worn and cracked...if so, it's possible that it could have shifted position to where it is making it tough for you to get into reverse.
You may also have an issue inside the tranny.
It will be impossible to tell without someone mechanically knowledgeable putting their hands on the tranny.
I would post up in your local s2ki forum and ask for a shop recommendation.
Old May 6, 2009 | 08:35 AM
SgtB's Avatar
Can you pull the shifter up any?
Old May 6, 2009 | 12:59 PM
fatjoe10's Avatar
does this still happen if you try 4th and then reverse?
Old May 6, 2009 | 01:01 PM
badboy00z's Avatar
I'll try selecting a different gear first. Not really sure if I can pull up on it. Never tried.
Old May 7, 2009 | 02:32 PM
s2kobsession's Avatar
try putting it in 5th, then pull back for neutral then push down and do reverse. I bet is works
Old May 8, 2009 | 02:19 AM
badboy00z's Avatar
I just looked at the service bulletin regarding the shifter problem. I'll just get it fixed and not have to do these tricks just to get it in gear.
Old May 8, 2009 | 11:24 AM
triddle's Avatar
[QUOTE=s2kobsession,May 7 2009, 02:32 PM]try putting it in 5th, then pull back for neutral then push down and do reverse.
cranked911
Jun 24, 2014 01:36 PM
chenpo
Mar 6, 2011 12:00 PM
SC-SUZUKA
Dec 21, 2006 06:27 AM
kfdon
Aug 30, 2006 05:34 PM
jal3lee
Nov 25, 2005 09:11 AM
