Head removal
Old Aug 5, 2017 | 02:54 PM
mongomery1234's Avatar
Default Head removal
Need a little assistance here removing the head. I've got everything off that I can see. Head moves there's a quarter inch or so between the block and the head all the way around minus the back right corner. It appears something is holding it under the intake manifold but I can't pinpoint it.
Old Aug 5, 2017 | 03:27 PM
flanders's Avatar
There is two support brackets holding the intake manifold, did you remove them?
Number 15 and 16 https://www.hondapartsnow.com/parts-...-manifold.html
Old Aug 6, 2017 | 03:23 AM
Slowcrash_101's Avatar
There's also a ground on the back of the head.
Old Aug 6, 2017 | 05:39 PM
Got that one looks like it was the bracket under the throttle body. Looks like the alternators gotta go to get it to unfortunately. So much hassle for a simple bracket.
Old Aug 6, 2017 | 06:42 PM
saving4one's Avatar
I didn't remove my alternator to get the head off. Maybe because I removed the intake manifold? And, after looking at your picture again, I took the tensioner pulley/bracket off also.
Old Aug 7, 2017 | 09:15 AM
Car Analogy's Avatar
Hopefully you loosened the head bolts properly. You have to loosen them in sequence, and only a little a time on each bolt. You go through the sequence multiple times loosening each bolt a little each time. Otherwise head will warp.
Old Aug 7, 2017 | 09:38 AM
Jaspah's Avatar
Probably one of the dowels sticking. if everything is loose (take of the intake mani!) Just pull it harder
Old Aug 8, 2017 | 03:40 PM
eld101's Avatar
Most likely the ground bolt, water temp sensor, or dowels.
liybzd
Jan 31, 2014 02:19 PM
JTNY
Oct 16, 2009 08:07 AM
jaeyon00
Jun 30, 2009 05:48 PM
John_Z
May 12, 2006 08:04 AM
FF2Skip
Aug 20, 2005 09:03 AM
