help (diagnostic trouble code)
Old Dec 12, 2007 | 06:02 AM
s2000-07's Avatar
Default help (diagnostic trouble code)
i have a DTC 27 (steering angle sensor), its a misalignment of the steering angle due to the toe adjustmnt that i did. i was able to fix it already and i am wondering how to clear the dtc with out having to use a honda diagnostic scanner.
thanks.
Old Dec 12, 2007 | 06:53 AM
Sinji's Avatar
go to autozone and pepboys and get a loaner scanner. that would be your best bet. other than that you'll need to pull out the "BACK UP" fuse in the under dash (driver's side) fuse panel for about 30 seconds. This will reset the ECU (computer) without losing your radio code (like if you disconnected the battery), but it will put the ECU back to the default settings. No big deal as it will learn again fairly quickly.
Here is the legend on the driver's kick panel:
Old Dec 12, 2007 | 11:24 AM
s2000-07's Avatar
thanks
viper_driver
Oct 5, 2022 07:52 PM
Muzzsjm
May 27, 2010 08:40 AM
philyoung
Jan 1, 2008 02:56 AM
stevoe88
Oct 20, 2007 08:12 PM
moey1188
Jul 4, 2006 08:21 AM
