HELP! ENGINE NOISE!
Old Jun 4, 2008 | 11:59 AM
  #41
SgtB's Avatar
Cool. You may have more than one problem. The tct may be totally separate from the valve leak. Good luck to you.
Old Jun 7, 2008 | 06:02 PM
  #42
Tjs S2k's Avatar
Originally Posted by REVHIR,Jun 2 2008, 08:40 PM
To tell you the truth you should look into the valve adjust first. I though it was my TCT at first then took it to my tuner and he readjusted the valves and the problem went away instantly. The ticking is still their like a deisel truck, but that is normal since my injectors are 880cc.
that seemed to do the trick. Honda said i had 6 valves really really loose. Got them adjusted and it put the zippity back in my doo dah lol. Id say thats what it was!
Old Jun 7, 2008 | 06:24 PM
  #43
tekstar's Avatar
glad to hear you solved your problem!
Old Jun 8, 2008 | 03:12 PM
  #44
SgtB's Avatar
Awesome.
Old Jun 8, 2008 | 07:06 PM
  #45
twohoos's Avatar
Don't want you to get paranoid, but if your retainers are cracking then a valve adjustment will only accelerate their failure. True, you've never over-revved, which is the cause of cracked retainers... On the other hand, have you had the car since new? A previous owner's over-rev could easily lead to a failure months or years later. Also, seems strange that the noise would just appear one day -- could be a crack that suddenly got worse.
Anyway, better safe than sorry -- you should check them out. Here's a summary/DIY replacement thread with links to other threads showing what to look for (without pulling the entire valvetrain):
https://www.s2ki.com/forums/index.php?showtopic=569714
Old Jun 9, 2008 | 08:12 AM
  #46
Tjs S2k's Avatar
still under warranty tho lol
Old Jun 9, 2008 | 05:10 PM
  #47
twohoos's Avatar
Your '01 is under warranty?!
Regardless, they won't cover cracked retainers, since it's evidence of overrev.
Old Jun 9, 2008 | 05:30 PM
  #48
negcamber's Avatar
Glad to hear that seems to have fixed the problem...
Curious if my cost estimate was close even though it looks like you went to a stealership...what did they charge you?
Old Jun 11, 2008 | 03:09 AM
  #49
Tjs S2k's Avatar
noise is still there not sure what it is now. Car runs fricken amazing. just kinda annoying, next on the list TCT
Old Jun 11, 2008 | 03:11 AM
  #50
Tjs S2k's Avatar
yeah aftermarket warranty. Called them already and they cover it. Still an 80 dollar service fee to check it out. I took it to honda last week and they quote "didnt see anything wrong with it"
MikeysFC
Jul 22, 2013 05:59 AM
s2000maniac
Jan 19, 2013 12:25 PM
viewmtrp
Jun 15, 2010 05:15 AM
j2s2k
Nov 17, 2009 06:29 PM
PalenkosBro
Jun 7, 2009 06:16 AM
