HELP! engine stalls by itself...
Old May 14, 2004 | 07:50 PM
kush only's Avatar
Default HELP! engine stalls by itself...
ok, heres the story.
im driving about 70 mph in 6th gear just cruising along then my car just dies. my radio stays on, headlights stays on, instrument panel background light stays on but the MPH, rpm meter, temp guage, gas guage all turn off. it was weired, i never seen this before. anyways, i pull over and start my car again and everything works fine. anyone know what could have caused this problem? thank you
Old May 14, 2004 | 08:20 PM
xviper's Avatar
Does your car have an alarm? OEM or aftermarket?
You need to provide more info.
Old May 14, 2004 | 08:30 PM
kush only's Avatar
[QUOTE]Originally posted by xviper
Old May 14, 2004 | 08:38 PM
xviper's Avatar
I was going to guess it had something to do with an alarm system but that's now ruled out.
Maybe your ECU had a brain fart and for whatever reason thought the key code was not the right one, disabling the fuel pump. But then, you said the instrument panel went blank too, so this might be an indication of a more critical ECU glitch.
Old May 15, 2004 | 07:07 AM
kush only's Avatar
should i take it in to the dealer? how are they gonna figure out what went wrong? anyways, i drove it about 50 miles on the highway just now and everything seems to be fine.
Old May 15, 2004 | 12:48 PM
xviper's Avatar
[QUOTE]Originally posted by AP1ayer
Old May 16, 2004 | 12:19 AM
S2KenC's Avatar
If it offers any value, I had the exact same problem when I had my 1995 Eclipse. Just cruising along at freeway speeds and the car jsut shuts off. It would do this probably once every other day.
XViper is dead-on. Problem is faulty ECU. My dealer replaced the ECU and it never happened again.
Old May 17, 2004 | 07:40 AM
kush only's Avatar
thanks for the help but i think i found my problem.
http://forums.s2ki.com/forums/showthread.p...threadid=207368
GT_NFR
Feb 8, 2016 06:24 AM
Lino8419
Sep 15, 2009 05:35 PM
Ade
Jul 19, 2002 02:46 AM
Baggs
Mar 22, 2001 07:12 AM
