Help me fix my accessory plug!
Hopefully this is the right place, but recently my 12v accessory outlet came loose and I have no idea how to get behind it to twist it back in, if anyone knows it would help.
Good luck. It's a bitch getting in there. I think I pulled off my center console (shifter surround) and then took out a couple of screws at the base of the console that has the accessory outlet. I then lifted it up as much as I could and crammed my hand in there. It's a tight fit.
There's a thread somewhere on this board that makes this a real easy fix. Instead of removing the entire rear section you just loosen 4 or 5 screws and squeeze your arm into the opening. People who read that thread fixed theirs in 15 minutes.
jwkim
09-18-2003 06:42 PM
