help spec stage 2 clutch buzzing
Old Aug 10, 2008 | 04:27 PM
leegungiah's Avatar
Default help spec stage 2 clutch buzzing
I have seen alot of posts about the Spec clutch buzzing on decal but has anyone found a solution?
Old Aug 10, 2008 | 05:26 PM
Mrfixit687's Avatar
Yea, get a ACT pressure plate stock disk combo.
Old Aug 10, 2008 | 07:00 PM
Slows2k's Avatar
Replace it with a quieter disc.
Old Aug 11, 2008 | 01:36 AM
leegungiah's Avatar
Thanks guy's
I spoke to David Norton at Spec Inc and this was his response.
(That unit has a high-performance spring rate in the disc hub..it's not made
to dampen the gearbox resonation. The only quiet option is the stock one
(or we can offer the stage 2 material that will fit a stock carrier) , but
the response isn't good and though the stocker dampens the noise, it doesn't
dampen the input shaft very well because the springs fully compress at a
higher rate. The performance unit is better for the transmission if you
drive the car hard.)
Legal Bill
Oct 6, 2017 07:26 AM
AZS2KDancer
Jul 16, 2014 03:34 AM
RedSunS2K
Feb 27, 2012 02:02 PM
Legal Bill
Sep 5, 2007 07:20 PM
Austblue
Mar 5, 2003 02:42 AM
