Help! Sputter sputter!
Old Feb 28, 2013 | 05:50 AM
hahapoopcorn's Avatar
Default Help! Sputter sputter!
Hello, I had recently switched out my test pipe and put my cat back in (the cat is in good condition) and since the switch my car has been sputtering during low rev loads and during idle. (sputtering with 2-3 second gaps in between) I took a shot in the dark and replaced the spark plugs (NGK laser plats) and I have no idea as to what to check next. Also, there is no check engine light. Any suggestions would be greatly appreciated. Thanks!
p.s. After the odd sputtering problem I had tried to put the test pipe back in but whether it's the test pipe or the cat the sputtering continues.
Old Feb 28, 2013 | 05:52 AM
Reckon's Avatar
Exhaust Leak? Are you sure it is all tightened up correctly?
Old Feb 28, 2013 | 05:56 AM
Hm, they were tightened pretty well and both gaskets have been replaced and sealed..
Old Feb 28, 2013 | 07:00 AM
Oh and other than idle the sputtering only lasts till about 2-2.5k rpm, then it is smooth sailing after that point.
jst2878
26
May 27, 2015 12:25 PM
ifly1956
Mar 8, 2010 04:27 PM
ZKilla55
Sep 30, 2009 02:47 PM
albe
Oct 1, 2007 11:33 AM
icecreamballer
Aug 14, 2005 12:12 AM
