honda ultra flange vs ultra flange 2
Old 10-15-2016, 12:30 AM
beefystud's Avatar
Default honda ultra flange vs ultra flange 2
i needed to reseal my oil pan, so i went to the honda dealership to get honda ultra flange 2 , they told me that honda doesnt sell it any more and that they only sell " ultra flange" i bought the ultra flange and used it but now that its dried it seems kind of soft and weak. did i use the right stuff or should i just have used hondabond ? the ap1 owners manual says to use ultra flange 2 and not honda bond but that was written 15 years ago and compounds and chemicals change , whats the right liquid gasket to use in the year 2016 ? is the "honda ultra flange" going to hold up or am i going to have to take it apart and use the modern hondabond? whats the right answer here ?
Old 10-15-2016, 02:59 AM
Slowcrash_101's Avatar
When it dries it forms like a stiff putty, it's only supposed to work as a gap filler not an adhesive. You only need a thin line, about as thick as the ink cartridge in a cheap pen, or spaghetti, or the little plastic part at the tip of a shoe lace.
Old 10-15-2016, 06:17 AM
dedonderosa's Avatar
Honda specifies in the manual you can use all 4 different sealants
HondaBond 4 pn# 08717-0004
Hondabond HT pn#08718-0001
Ultraflange pn# 08718-0003
UltraFlange II pn#08718-0009
any will work just fine, and as stated just a thin line on the pan dont over do it. and also wait about 30 min before filling with oil so it has time to cure.
Old 10-15-2016, 11:05 AM
beefystud's Avatar
it did not dry like stiff puddy , more like soft rubber like a deflated rubber balloon, regardless its still leaking oil from the bell housing
Old 10-15-2016, 05:14 PM
Did you draw a continuous line with no breaks making sure to draw inside the bolt holes and not outside? Did you hand tighten the bolts in sequence, wait a few minutes before torquing them down in steps?
Legal Bill
12-30-2012 02:49 PM
nse2167
06-01-2009 01:49 PM
chuhsi
12-02-2008 10:52 PM
Quick Reply: honda ultra flange vs ultra flange 2
