Immobilizer
Old Jun 27, 2008 | 10:16 AM
no-cones's Avatar
Default Immobilizer
I purchased an 01 JDM ECU for my 05. I found out after taking it to the dealer that in 05 they changed to a rolling code and therefore I can not use the ecu because it will not program to the key.
I know there are ways around this problem. One is bypassing the immobilizer. I also realize that after searching that his is not something to be discussed on an open forum.
However, I would appreciate if someone would PM me with inf on how to get around the immobilizer or any inf in how to solve this problem.
Thanks in advance......Rich
Old Jun 27, 2008 | 03:39 PM
Slows2k's Avatar
Pretty sure the JDM 01 PCM doesn't have an immobilizer and is wired differently than a USDM car.
Old Jun 27, 2008 | 04:27 PM
no-cones's Avatar
I installed it and the car would not start. the dash lit up but did not start.
I was wondering if this would work. See link
http://www.drdetailshop.com/Transponderreference.htm
Any help would be appreciated. Rich
Old Jun 29, 2008 | 01:51 PM
no-cones's Avatar
Could I use a Greddy emanage ult with my existing ECU to raise the rev limit?
Old Jun 29, 2008 | 02:27 PM
negcamber's Avatar
^^ I understand that you can.
Old Jun 29, 2008 | 03:45 PM
vspc2nr's Avatar
i have a question also. I have a 00 and i've heard you can get better overall gas and throttle responce with a ECU swap. Is it true?? Of so, which ones would/will work. Do i have to do the same with the immobilizer??
Old Jun 29, 2008 | 04:09 PM
no-cones's Avatar
From my limited knowledge, here is my understanding. The first versions of the ecu, which is printed on the label. eg A01. This would indicate that the ecu is for the USA = A the 0= manual, 1= version. These were programed to run a little rich in the AF mixture. Later versions were a little leaner. As for identification I found the link below.
http://www.hondata.com/techecuid.html
It is also my understanding that ecu's are interchangable between the years 00 and 04 because they have a fixed code. However, your key must be matched to the ecu and this is done by a Honda dealer. These versions have a fixed code. The 05,which I have, uses a rolling code.
Whether throttle response and fuel milage improve, I am not sure.
Hope this helps....Rich
Old Jun 29, 2008 | 05:48 PM
vspc2nr's Avatar
^^ THANKS MANG!!
PRedS2K
Apr 2, 2009 04:29 PM
mog2000
Feb 22, 2007 04:24 PM
00s2k9k
Sep 6, 2005 06:54 PM
SsamJang
Mar 22, 2004 10:27 AM
SsamJang
Feb 26, 2004 06:00 AM
