Loose Frame and Rack and Pinion
Old Jun 24, 2004 | 02:00 PM
johnnyhfm1's Avatar
Default Loose Frame and Rack and Pinion
Has anyone experienced a problem with the sub-frame becomming loose and causes the car to "wander" around on the road and when you accelerate out of a turn on an uneven surface the front end sounds like it is falling out. The dealer tightened it up and it helped for a little while but it is loose again after a few hundred miles. Any suggestions?
Old Jun 24, 2004 | 02:24 PM
xviper's Avatar
This is a new one for me. Did this all begin to happen sometime after a clutch job? They may not have lifted the engine cradle to the proper place and secured it.
Old Jun 24, 2004 | 02:42 PM
kane.s2k's Avatar
My sub-frame bolts on the driver side were loose as a goose and would also make the car "wander" a bit. Never noticed that on my friends S. That's how I got it from the factory. When I went to take the front subframe off to pull the engine out, the bolts on the driver side could be removed by hand while the passenger side took a bit more work.
I also found a nut lodged in between my top A/C compressor mount and a piece of a wrapper (japanese writing) under the passenger side engine mount.
I really wonder what else I can find while taking things off.
Old Jun 24, 2004 | 03:02 PM
johnnyhfm1's Avatar
The clutch was replaced before I purchased the car. Would the dealer have picked up on the engine cradle position when they were tightening everything up? The rack and pinion was loose as well. Not sure if that points to anything. Think an aftermarket brace would help?
Old Jun 24, 2004 | 03:52 PM
xviper's Avatar
[QUOTE]Originally posted by johnnyhfm1
Old Jun 25, 2004 | 05:53 AM
slipstream444's Avatar
-Matt
Feb 17, 2016 06:39 PM
bigearl91
Jan 9, 2016 05:34 PM
rikhemi
Apr 4, 2013 06:24 AM
rikhemi
Dec 25, 2012 06:18 AM
JeffreyMartin
May 30, 2012 09:34 AM
