loose steering problem
Old May 28, 2009 | 06:26 AM
type-j's Avatar
Default loose steering problem
Hey, i've noticed that my steering feels really loose and has some play to it compared to a friends s2k that i drove. the car is stock with only 18k miles on it and nothing was ever changed. tire pressure looks ok and it drives straight. i also noticed that when i parked on a friends sloped driveway with the wheel turned to the right is started shaking back and fourth pretty violently. any ideas on what the problem could be?
Thanks.
Old May 28, 2009 | 06:33 AM
S2Kage's Avatar
did you hit anything? did anything "hit' you? could be a whole host of things... check ur lug nuts? Tie rod?
Old May 28, 2009 | 06:39 AM
type-j's Avatar
nope never hit anything, alignment is straight, lugs are tight. could it be the steering rack? i had someone hook up some lights under my dash and they removed the plastic around the ignition and pulled a plug but everything was put back and i dont think that would affect the steering?
Old May 28, 2009 | 05:24 PM
negcamber's Avatar
There are two universal joints...the upper one may be causing that play.
There is also a ball bearing in the steering column just behind the steering wheel. That can also make the wheel feel like it has some play in it.
Old May 28, 2009 | 05:28 PM
zzziippyyy's Avatar
is this only when parked?
Old May 29, 2009 | 06:33 AM
type-j's Avatar
any way to remedy this? is it just a matter of tightening some bolts? i read about the steering coupler bolts but usually people had loose ones after they did major work to their car like engine removal and clutch changes.
agy2k2
Aug 12, 2014 11:49 AM
s2k_suprchrgd
Jul 2, 2010 12:19 PM
Master Apex
Sep 12, 2008 12:18 PM
stvtrnr
Sep 23, 2007 08:19 PM
Sbeall
May 13, 2004 03:52 AM
