Maintenance Advice
Old Mar 6, 2019 | 05:10 PM
NotThePatrick's Avatar
Default Maintenance Advice
Hello,
I recently bought a 2005 Honda S2000 a couple months ago (My first car). I was wondering if anyone had any advice to properly maintain the car. (when to change the oil?, what type of oil to use?, replace the timing belt/chain?, checking the suspension/alignment?, checking the brakes?, interior maintenance advice?)
When I bought the car, it had roughly 98,000 miles. It currently has 105,000 and is running fine with no major problems. I am not too car savvy, but this is my first car and I would really like to take care of it. Thanks!!!
Old Mar 6, 2019 | 06:05 PM
beefystud's Avatar
DONT use royal purple transmission fluid , use honda Manuel transmission fluid or gm syncro with friction mod
DO use royal purple 10w-30 in the engine
brakes will let you know when they need to be changed......
leave timing chain alone forever unless it starts making noise
get takeda intake/big bore thottle body/ ported intake manifold
buy a life time alignment from firestone
interior = leather wipes and a vacuum cleaner + windex
buy rpf1's from tirerack
get new spark plugs ngk platinum
buy all your oem honda parts from majestic honda and all your after market stuff from evasive and nemos
your valves are probably perfect
your intake manifold gasket is probably toast
Old Mar 6, 2019 | 06:32 PM
Car Analogy's Avatar
There is a thread called info for new owners (or something to that effect). Its chock full of everything you could possibly want or need to know. It's concentrated on exactly what you are asking.
Old Mar 6, 2019 | 08:53 PM
outeiroj's Avatar
can confirm this is one of the best value investments you can make. purchased my s2000 in 2013 and have gotten it aligned twice a year since, easily paid for itself
also i would advise replacing your coolant, trans, rear diff fluid and brake fluid as preventative maint
Old Apr 10, 2020 | 02:20 PM
HardFlip's Avatar
Mileage and spring rates on the ohlins/springs? Thanks
Old Apr 12, 2020 | 03:47 AM
Slowcrash_101's Avatar
Twice a year? You must be thrashing the car with slicks. I only adjust front toe to zero. In 3 years after replacing all bushings and ball joints my alignment hasn't changed at all other than a small change in front toe.
Old Apr 12, 2020 | 03:54 AM
windhund116's Avatar
Don't think outeiroj will response. Posted too long ago. If you need alignment every 6 months, prolly driving on potholed roads and/or using the "feel" technique to park, by the curb.
Old May 30, 2020 | 05:39 PM
ShellKace's Avatar
do you have pictures of the exhaust and test pipe?
JayC07
Oct 23, 2012 12:04 PM
achon95
May 27, 2011 10:59 AM
MY00S2000
May 25, 2010 09:57 AM
m1sterlaw
Nov 4, 2009 03:51 PM
Lord-Jaffa
Feb 25, 2009 05:52 AM
