Maintenance Light blinking
Old Jun 21, 2003 | 01:13 AM
Jibb47's Avatar
Default Maintenance Light blinking
So tonight when coming home from from a movie at 1:00 AM, I decided to open it up on the empty, wide open freeway. I downshifted and took it to vtec a few times and once I got off the freeway, I see the maintenance required light start blinking. After 10-20 seconds it suddenly turns off and doesnt light up the rest of the way home. Should I be worried about this? I just got an oil change 20-30 miles ago if that makes any difference. Someone please put my mind at ease and tell me that I havent hurt my car. Thanks in advance.
Old Jun 21, 2003 | 02:21 AM
mwy23's Avatar
you didnt hurt your car. a check-engine light is bad. maintenance light is useless.
Old Jun 21, 2003 | 02:31 AM
mustangkiller's Avatar
the light flashes after 6k miles and remind you its time for service
meaing take it to the dealer it will stay on after 12k, if you service it yourself (change oil and check fluids) the owners manual tells how to put the ligt out its easy has something to do with ip button
Old Jun 21, 2003 | 05:26 AM
CoralDoc's Avatar
About 6k miles after being reset, the Maintenance light will blink for several seconds. After that it will blink for several seconds after each time you start the car. After about another 1k miles it will come on and stay on whenever the ignition is on.
To reset it follow these instructions listed in the S2Ki library as a helpful FAQ.
Old Jun 21, 2003 | 05:53 AM
Xplosiv's Avatar
CEL doesnt have to mean anything bad, I can swap the cat. with a test pipe and I will get the CEL instantly, CEL works with all the OBD2 sensors, and if one of the sensors is eliminated/not functional, the ECU will also give you a CEL. I do agree that maintenance light is useless.
Old Jun 21, 2003 | 11:09 AM
Jibb47's Avatar
Thanks guys.
Old Jun 21, 2003 | 12:24 PM
mwy23's Avatar
[QUOTE]Originally posted by Xplosiv
[B]CEL doesnt have to mean anything bad, I can swap the cat. with a test pipe and I will get the CEL instantly, CEL works with all the OBD2 sensors, and if one of the sensors is eliminated/not functional, the ECU will also give you a CEL.
Old Jun 21, 2003 | 12:25 PM
Xplosiv's Avatar
true, I'd rather get a mant. light than a CEL light
Old Jun 25, 2003 | 06:12 AM
inger's Avatar
Thanks again for the info. I was having a very similar issue with my car. It's just past 6000 miles.
SD_S2K
San Diego S2000 Owners
May 25, 2007 10:14 AM
emrillive
Oct 21, 2004 12:42 PM
ant_knee
Jan 31, 2003 10:23 AM
bboersma
Nov 13, 2002 11:39 AM
kumar75150
Nov 13, 2001 01:08 PM
