Metal shavings on oil drain plug.
Old 05-15-2005, 05:57 PM
sebrings2k's Avatar
Default Metal shavings on oil drain plug.
During an oil change today I noticed a small amount of very fine metal shavings when I wiped off the magnetic drain plug. Should I be concerned? The size of the shavings were compareable to dust.
Old 05-15-2005, 06:01 PM
xviper's Avatar
By your description, I wouldn't worry. I too, have the magnetic drain plug and have seen similar "dust" particles. This was at the same interval when my oil analysis came back indicating my engine was doing fine (as far as the oil was concerned). Now, if you were to get shavings like what you would see on the diff drain plug, then worry. It's OK for the diff but not for the crankcase oil.
GrandMasterKhan
11-05-2009 05:34 PM
VIC4UF
10-02-2005 03:40 PM
jmargelo
05-09-2005 05:26 PM
mm2000
12-07-2004 08:36 PM
emrillive
06-03-2004 10:21 PM
Quick Reply: Metal shavings on oil drain plug.
