Is my differential going?
Old May 15, 2019 | 08:14 PM
Zer0ne's Avatar
Default Is my differential going?
SOLVED RATTLE: Axle boot clamp came loose and was smacking the suspension parts as it rotated. Clunk still there.
Recently developed this metallic rattling above ~55mph. Happens in all gears and when rolling in neutral. Initially took the car in because I had a clunk while shifting/getting on and off the throttle sometimes. Mechanic swapped my CV cups side to side to alleviate vibration under acceleration and also had the axles replaced with OEM ones while swapping the cups to see if it would fix the clunk, no go. Clunk is still there and now this rattling developed less than two weeks later. Also, the rattling happens after the car gets up to temperature. Isn’t present when cold. Mechanic did mention that the diff my be on it’s way out. Wanted to get some opinions on here. Here’s the rattling sound:
Thanks!
Old May 15, 2019 | 11:14 PM
nubbel's Avatar
What does the magnet on the drain plug of the diff look like?
Old May 16, 2019 | 12:27 AM
Zer0ne's Avatar
I haven't checked that yet. Going to get underneath her this weekend and check the drain bolt, mounts/bushings, axles, and prop shaft.
Old May 16, 2019 | 03:01 AM
zeroptzero's Avatar
make sure the axle nuts are properly torqued, based on the new spec not the old spec in the shop manual, since the axles were swapped that might be a logical place to start.
Old May 16, 2019 | 05:02 AM
Zer0ne's Avatar
Definitely not the axle click. Dealt with that before and know that sound 100%.
bgoetz
May 18, 2018 11:14 AM
onions2k
Jul 10, 2014 06:21 AM
21337R
Apr 22, 2010 10:08 PM
news2kroller
Sep 20, 2006 10:04 AM
Hyper_R
18
Jul 13, 2006 12:47 AM
