Need Advice
Old Mar 3, 2010 | 09:37 PM
R.O.C.'s Avatar
Default Need Advice
Hey Guys! Im am going to to a valve job pretty soon and i want to change my valves, retainers, springs, and headgasket. My car is pretty stock just have a cold air intake and i plan to modify my car a bit in the future. My car is a daily driver. What do you guys recommend me getting as far as valves,retainer,springs, & headgasket?
Thanks a lot for you input!
Old Mar 4, 2010 | 02:48 PM
SPFSkyline's Avatar
Stock springs and valves are fine, upgrade to AP2 retainers, unless you are going FI or new cams. Stock HG is good also unless going to FI and lowering compression. What are you trying to get out of doing the "upgrade"?
Old Mar 4, 2010 | 03:38 PM
xeuxx's Avatar
Just do an adjustment and switch to AP2 retainers.
Old Mar 4, 2010 | 09:29 PM
R.O.C.'s Avatar
Well i have all the misfire codes and my car is running like crap at low rpms...i have definitely lost power. i have basically done just about everything that there is on the misfire thread. Now i believe i have a cracked retainer or sumtin......and i decided that i am going to do a valve job. While i am at it i want to change my valves,springs,retainers and head gasket.
Old Mar 4, 2010 | 09:52 PM
R.O.C.'s Avatar
and im trying to see if aftermarket valvetrain will benefit me as far as to make my car a bit more fun to drive as it is my daily driver. Ive been looking at valves, valve springs and retainers from Brian Crower and Skunk2. Is it best to go this route, or stick with oem ap2 stuff. I dont plan to go forced induction anytime soon, but im not looking at aftermarket camshafts or cams either...dont have the cash yet....any help would be appreciated!!
Old Mar 5, 2010 | 04:42 AM
charliec225's Avatar
With it being your daily driver, I'd stick to OEM. If you were doing an NA build and wanted to squeeze every last HP out, maybe aftermarket would be okay, but I'd value reliability and longevity over maximum performance. Besides, the OEM equipment is damn good. Honda didn't really cut a lot of corners when they made the S2000.
Old Mar 5, 2010 | 05:07 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Best advice you will get.
Stay away from the aftermarket stuff. It will not go the distance like OEM.
I'd get a proper diagnosis before you get into unnecessary engine work.
AZ-S2000
Mar 20, 2015 01:36 PM
S2K_Vtec
Apr 15, 2014 11:38 AM
JoeyBalls
Oct 15, 2009 09:43 AM
jaeyon00
Jun 15, 2009 09:04 AM
Tjs S2k
Oct 13, 2008 06:23 AM
