need help with oil leak
I'm getting drips from this area at the top front passenger side of the engine. I can't tell for sure exactly where it's coming from, but it's somewhere around this part in the photo below. You can even see some of the oil drops on the floor beneath it. Anyone have any idea what here would be likely to be leaking, and how to fix it?
If the solenoid leaks commonly, I'm guessing maybe that's it. Do I need to replace it?
The last one on your list should be the oil pressure sensor. Do all the other ones as they're easy to replace and not expensive. Chances are you'll need to replace them all eventually might as well do it now and never have to do it again for 10 years.
