need help to reset abs light
Old Aug 17, 2004 | 06:15 PM
intake's Avatar
Question need help to reset abs light
need help, my S was hit in the rear wheel i replaced the wheel assembly and axle shaft and now abs light is on.I do not want to pay honda to reset it please help.
Old Aug 17, 2004 | 07:22 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Resetting it will not help. You likely have an open in the wheel sensor circuit, due to a tugged wire. The abs has it's own diagnostics and code system. A scan will tell you exactly what the problem is.
Old Aug 17, 2004 | 08:03 PM
Slows2k's Avatar
The light is on for a reason, something is wrong with the system. Most likely due to your accident. Possibilities are: damaged wiring, pulser ring on the axle, or wheel speed sensor.
Even if you clear the code, unless you fix the problem it will come back on.
Old Aug 17, 2004 | 10:15 PM
slipstream444's Avatar
Spot on.
I Had the ABS light induced by my Right Rear wheel sensor showing an open. The cause was most likely an accidental tug on the cable (by me) when I was installing my new '04 diff with 4.57 gears.
My dealership ran the code (for free) and narrowed it down to the sensor mentioned above. Luckily, I had a spare sensor from a used JDM subframe and I just spliced it in. The light will go out once the computer sees the problem is resolved.
You can get a sensor from the dealer ($110), from the marketplace on this site, or you can get one from a junk yard and splice it in. There's nothing magical about the sensor itself ... two wires that you can solder together and seal with shrink tube. Check the resistance; it should be somewhere close to 1.4 ohms (~1.36-1.43)
jsenclosure
Apr 23, 2012 06:51 PM
Spec_Ops2087
Nov 22, 2010 11:10 AM
RedAP2S2K
May 17, 2009 02:56 PM
Hyper_R
Jun 23, 2008 10:57 PM
intake
Aug 21, 2004 02:07 PM
