No power
Old Oct 26, 2024 | 09:58 PM
Sumosou's Avatar
Default No power
Left the headlight on overnight and my battery drained. i hooked a jump box and crank the car. the car cranked a couple of time and then i lost all power to the car. battery has 5-6 volts, i replace a couple of 10 and 15 amp fuses but still have no power. i checked every fuse and relay in the car minus the main relay. i also swapped the 100 and 40 amp fuse for the main battery but still nothing. i tried the horn and hazards to confirm the car had no power, when the key is in the ignition while the door is open i dont even hear the beeping noise. any suggestion on what to check.
Old Oct 27, 2024 | 02:46 AM
Scigheras's Avatar
Fully charge the battery and try again
Old Oct 27, 2024 | 02:47 AM
flanders's Avatar
So battery only has 5-6V?
You need to try and charge it or probably replace it.
Old Oct 27, 2024 | 05:08 AM
Chuck S's Avatar
Battery is likely irreparably damaged as 10.5vDC is stone dead and this is half that voltage. Voltage may be too low for a battery charger to even start charging it -- charger won't detect the battery is even there.
-- Chuck
Old Oct 27, 2024 | 08:51 AM
noodels's Avatar
As above put on charge a few times and may come into life again ..
Old Oct 27, 2024 | 09:39 AM
windhund116's Avatar
Prolly needs several hours of charging. Depending on the charger, it could take overnight.
Old Oct 27, 2024 | 09:47 AM
cosmomiller's Avatar
Top Answer: 1
When this is over you may see flickering lights on the dashboard. If that is the case you may need a new rectifier in the alternator. This can happen after jump starting this car with a shot battery.
ryiin2
Apr 23, 2018 05:19 PM
Kdlopez01
May 5, 2009 09:57 PM
stolitonic22
Nov 8, 2007 01:30 PM
prodigy3006
Oct 6, 2006 09:02 AM
Kibro
Sep 16, 2001 08:11 PM
