OEM exhaust and test pipe Chime in please~! HELP
It wouldn't bolt on
something down there is tweaked man. are you sure you didn't hear this noise before the TP was on? You shouldn't hear any noise from it inside the car (at idle) and it should just be normal exhaust sound (albeit with the new tone) when on the throttle.
I run this setup and the only hiss I hear is comes from the front end. Sounds like you have an exhaust leak at the tp/exhaust joint. Maybe the shop installed the test pipe backwards i.e. they confused the left/right sides
Originally Posted by vtec9,Feb 17 2007, 06:47 PM
It wouldn't bolt on
something down there is tweaked man. are you sure you didn't hear this noise before the TP was on? You shouldn't hear any noise from it inside the car (at idle) and it should just be normal exhaust sound (albeit with the new tone) when on the throttle.my sol had a test pipe also...i had the same noise too. maybe it's normal? i just checked for leaks again and no leaks at idle or gas. i want to put it on a stand and put some load on it.
Originally Posted by John_Z,Feb 17 2007, 08:50 PM
Look for black sooty "whisps" around the connection.
I have the Berk TP recently installed on MY04.
After the install and in additon to a throatier exhaust I hear a very slight metallic like note or whistle that wasn't there previously... I have thoroughly checked for leaks etc - I attribute the 'new' sound to be increased air flow...
BowlofRice
Jun 5, 2011 04:45 PM
hellaSleepy
Apr 14, 2011 08:04 AM
