OEM front spoiler installation question
Just installed the front lip - looks great - can't believe how it changes the look of the car. I did it in weather above 60 degrees (about 75 to be exact) as the instructions recommend due to the need to get the tape to stick. I did the job three days ago - and haven't driven the car since.
The question is this - the sucker is bolted on tight, but the lip will pull back from the top if you test it. I tried it out to see how tight it was. Some areas are very tight and won't pull back, but parts of the front will pull back (maybe 1 or 2 mm). It's not much, and I'm not worried about rubbing since the area that pulls back has the rubber contact, but I wanted to check with you guys just in case.
Thanks in advance.
Thanks in advance.
Thanks WI. I don't see a gap unless I check the stickiness of the tape-to-the-bumper by squeezing on the lip. Squeezing reveals that the gap will open up 1-2 mm - thereby indicating that the tape isn't sticking too well.
Just sitting there - it's contact all the way around.
how much is it usually to get the lip installed? , and does anybody have instructions of doing on there own , i just purchased the seibon CF front lip , it has no screws and came with nothing but a lip , any advice??
No drilling or mods required to install. Everything goes on perfect - just as the instructions that come with it say. It does help to have a helper to hold one end of the lip while you mess with the other end.
There was one slight surprise though. The directions state that you should remove clips that are already on the car. I didn't do this because there is absolutely no benefit to it. The clips don't even come close to the area the lip rests on. I re-read the instructions about 10 times and thought I was retarded, but decided not to do it. Glad I didn't because those things sometimes get broken and you have to buy new ones.
I'm pretty technically challenged and I'm glad I didn't bother taking it to someone to do.
