Performance Chip
Old Sep 26, 2002 | 02:22 PM
  #21
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by Mikey
[B]
I've also developed software for many years.
Old Sep 26, 2002 | 03:03 PM
  #22
Mikey's Avatar
Originally posted by gernby
If there is no need to share information between the ECU and the ABS system, then I guarantee that the designers left that data path out.
Fair enough, you'll get no disagreement from me that most performance chips merely change maps, however a lot more is possible. As I posted earlier, wheel sensors are not required to manage effective traction control.
The sensorless approach to traction control is tried and true and could almost certainly be accomplished with a bit of new code loaded into stock ECU. It wouldn't require wheel speed sensors or any interface to the ABS system. The only hardware requirement would be the ability to monitor the ignition, analyze data and retard the spark. The hardware to accomplish these functions is most certainly included in every stock ECU.
Reprogramming the ECU would be no easy task without access to the application development environment. However, once the new code was developed, it certainly "could" be as simple as a one chip replacement. Especially if as I suspect, the system software were just sitting on a ROM.
wang_uk
Oct 21, 2005 06:06 AM
Elistan
Jul 29, 2002 10:40 AM
pfb
Mar 26, 2002 02:16 AM
jays2000
Feb 19, 2002 10:56 AM
yellows2000
Nov 9, 2001 10:47 AM
