power up electrical with trans and motor removed?
Old 02-01-2015, 02:28 PM
Runninlo's Avatar
Default power up electrical with trans and motor removed?
I have the motor and trans out of my baby longer than planned due to a scammer seller sending me a bad motor. My question is this. I pulled the battery and followed the Honda factory service manual steps to remove the motor and trans but now I need to roll up my windows. Car is getting dusty and I would like to wash and cover. Can I connect the battery, turn the key on and roll up the windows without doing harm to the ECU or other electronics. No wires were cut and all harnesses have been secured neatly under the hood while I wait for the motor issue to be resolved.
It seems like it should be fine but better safe than sorry,
Josh
Old 02-01-2015, 02:48 PM
zeroptzero's Avatar
Received 3,391 Likes on 2,462 Posts
Your fuel pump will energize and you will get a rush of fuel pouring out of the fuel line which would be disconnected. If you pull the fuel pump fuse you might be safe though. The windows should work as the engine ground removals should not affect the windows.
Old 02-01-2015, 03:12 PM
Runninlo's Avatar
See that's why I asked I totally spaced the fuel pump. I'll pull the fuse.
Thanks,
Josh
#1turbos2k
05-25-2012 09:58 AM
ack5252
06-18-2011 03:09 PM
s2konroids
08-18-2010 12:36 PM
GDM S2K
01-08-2007 08:48 AM
klns2k
11-07-2006 12:09 PM
Quick Reply: power up electrical with trans and motor removed?
