problem when drive off freeway ramp
when i drive my s2 on and off freeway ramp, i have to correct the steering wheel at least 2 times.
does this happen to you guys also?
however, when i drive my friend's BMW, i can just get over without adjust the steering wheel at all.
my car had one accident before.
so, can it be the frame damage that causes the problem?
What a BMW can or can't do under similar circumstances may have no bearing on what's going on in this scenario. A BMW may behave the way it does because of tire size, suspension settings, vehicle weight, wheelbase, degree of power steering assist, etc. What you need to do is to duplicate this manouver in an S2000 that has NOT been in an accident before and is otherwise similar to your car in terms of mods.
Did you have to do this same correction BEFORE your car was in an accident? Has that particular piece of road changed in any way since then? Has your car been properly repaired and re-aligned since the accident?
"Did you have to do this same correction BEFORE your car was in an accident? "
i don't remember that's why i want to check with you guys.
"Has your car been properly repaired and re-aligned since the accident?"
yes
"Has that particular piece of road changed in any way since then?"
happens on almost all large radius freeway ramps.
yes
