Propeller/Drive Shaft grease seal leak.
Old 06-23-2019, 07:48 AM
S000M's Avatar
Default Propeller/Drive Shaft grease seal leak.
While I was doing rear brake inspection on my 03 yesterday I noticed that grease has been spinning off from my propeller shaft at the rear flex joint where it connects before the differential (134,000 miles). Looks like fairly recent occurrence. Have not heard of this before and I have owned car for 13 yrs now. A Honda service tech told me it's a "hydraulic" type seal & compared it to fluid filled motor mounts. I have not noticed any vibration or anything when driving and I just drove Sebring race track last month. What can I expect to experience before failure. How long will it last. You can't see anything worn or cracked at the joint, just that grease has been slung and radiating directly outwards on underside of car. I'm hoping I can find a used replacement shaft. The part numbers are the same for 00-03. Then in 04-09 the last 3 digits change from 024 to A02. Is the AP1 shaft different than the AP2's? The new OEM price is the same for all years. Any input or guidance is appreciated. I am aware of paint markings to match when removal and have done so when I did an 05 engine swap about 5 years ago. Thank you.
Old 06-23-2019, 09:11 AM
Car Analogy's Avatar
Received 1,321 Likes on 999 Posts
You can buy an aftermarket boot, and repack it yourself. Its nothing like a sealed diff or motor mount.
There is a diy on where to buy boot and how to. Do both ends.
Old 06-23-2019, 09:33 AM
noodels's Avatar
^^ its the rear UJ on prop, not the half shaft boot.
Old 06-23-2019, 01:43 PM
Yes, I know. There is a grease repack diy with boot replacement for propshaft. The propshaft uses cv joints, just like the half shafts. They are removable. The propshaft has a splined shaft on each end, front and rear.
Old 06-23-2019, 11:11 PM
noodels's Avatar
Oh ok
alricl
12-15-2010 07:23 PM
vtecb
10-27-2010 07:02 PM
ravi1987
09-12-2009 03:04 PM
Jack_in_the_Box
03-23-2007 01:57 PM
collins2068
09-07-2006 03:47 PM
Quick Reply: Propeller/Drive Shaft grease seal leak.
