Pulling code P0607--Thoughts anyone?
Old May 19, 2006 | 01:10 PM
trapper's Avatar
Default Pulling code P0607--Thoughts anyone?
Well, I got my new code puller today. Hooked it up to our Van and everything OK [no codes stored]. Then I hooked it up to my S2000 [MY 2004] and pulled code P0607 [Control Module Performance].
The MIL light is NOT on when the engine is running.
The car is running fine with none of the common complaints [idling, gas mileage, power loss etc.].
Following instructions in the Helm
Old May 19, 2006 | 05:07 PM
RadioZero's Avatar
what software version is on your 3110? i updated mine via the website. when it boots up it flashes across the screen and i am running version 1.3
i had No stored DTC's when i scanned my 2006.
make sure your running the latest software on the 3110 and try again.
also the Helms mentions a low battery and/or jump starting the car. check your battery with a volt meter, car running and not running.
Old May 20, 2006 | 04:37 PM
trapper's Avatar
Thanks for your reply.
My scanner was delivered with V1.3 software installed. The website had no newer updates for it or the PCLink.
Battery was OK. 12V+ off; 14V- running.
I now believe the problem is a false alarm.
I think the DTC originated a couple of months ago when I blew fuse #25 [and one other] doing something stupid [don
Old May 21, 2006 | 12:29 AM
Eluded's Avatar
I looked at my Helm's but its for a AP1 No code 0607 but searching for 607 turned up this:
DTC Pl607:
ECM Internal Circuit Malfunction
1. Reset the ECM (see page ll-4)
2. Turn the ignition switch ON {ll).
3. Wait 30 seconds is DTC P1607 indicated?
YES - Substitute a known-good ECM and recheck(see page 1 1-5). lf the symptom/indication goes away, replace the original ECM.
NO - Goto step 4.
4. Turn the ignition switch OFF.
5. Turn the ignition switch ON (ll).
6. Wait 10 seconds is DTC P1607 indicated?
YES- Substitute a known-good ECM and recheck{see page 11-5). lf the symptom/indication goes away, replace the original ECM.
NO -Intermittent failure, system is OK at this time. Ask the customer if the battery ever went dead.
Not sure if any of that helps. Good luck.
Old May 21, 2006 | 04:39 AM
trapper's Avatar
[QUOTE=Eluded,May 21 2006, 03:29 AM]I looked at my Helm's but its for a AP1
gwnorth
Aug 6, 2017 11:03 AM
K24S2000
Aug 5, 2015 07:52 AM
S2K1DAY
Jun 5, 2010 09:07 AM
r8byb
Apr 15, 2009 09:17 AM
PapiChulo
May 3, 2005 05:18 PM
