Pulling code P0607--Thoughts anyone?
Well, I got my new code puller today. Hooked it up to our Van and everything OK [no codes stored]. Then I hooked it up to my S2000 [MY 2004] and pulled code P0607 [Control Module Performance].
The MIL light is NOT on when the engine is running.
The car is running fine with none of the common complaints [idling, gas mileage, power loss etc.].
Following instructions in the Helm
what software version is on your 3110? i updated mine via the website. when it boots up it flashes across the screen and i am running version 1.3
i had No stored DTC's when i scanned my 2006.
make sure your running the latest software on the 3110 and try again.
also the Helms mentions a low battery and/or jump starting the car. check your battery with a volt meter, car running and not running.
Thanks for your reply.
My scanner was delivered with V1.3 software installed. The website had no newer updates for it or the PCLink.
Battery was OK. 12V+ off; 14V- running.
I now believe the problem is a false alarm.
I think the DTC originated a couple of months ago when I blew fuse #25 [and one other] doing something stupid [don
I looked at my Helm's but its for a AP1
No code 0607 but searching for 607 turned up this:
DTC Pl607:
ECM Internal Circuit Malfunction
1. Reset the ECM (see page ll-4)
2. Turn the ignition switch ON {ll).
3. Wait 30 seconds is DTC P1607 indicated?
YES - Substitute a known-good ECM and recheck(see page 1 1-5). lf the symptom/indication goes away, replace the original ECM.
NO - Goto step 4.
4. Turn the ignition switch OFF.
5. Turn the ignition switch ON (ll).
6. Wait 10 seconds is DTC P1607 indicated?
YES- Substitute a known-good ECM and recheck{see page 11-5). lf the symptom/indication goes away, replace the original ECM.
NO -Intermittent failure, system is OK at this time. Ask the customer if the battery ever went dead.
Not sure if any of that helps. Good luck.
No code 0607 but searching for 607 turned up this:DTC Pl607:
NO - Goto step 4.
