Really bad fuel economy after tune
I got my car tuned a few weeks ago and well while the tune seems fine (power is good), I have lost a lot of fuel economy. Before on the greddy emanage ultimate system that I was on I would average 230-250 miles per tank. Whereas now that I am using the aem v2 and re tuned I get maybe 130-150miles per tank.
My AFR are currently only managed via open loop because I haven't wired my wideband into the aem. Could this be a huge culprit? Also on a cold start I often have very very very little power and will be running very rich 11-12.5 @ idle, after about 30minutes it goes up to 13.3/13.6 @ idle. I'm also going to get replace my plugs just in case.
Thanks for your input.
If you replace your plugs I highly recommend NGK Iridium race plugs (BKR8EIX). Higher detonation threshold and tangible improvement in performance throughout the rev range on NA or boosted cars.
ryiin2 (02-21-2018)
That's exactly the problem - over-fuelling. If you take a whiff of your dipstick after a drive does it smell like gasoline? Like a strong smell of gas?
It should automatically adjust but for safety sake get your tuner to give it a once over immediately after the install to make sure.
ryiin2 (02-22-2018)
You don't need a wideband to run the car in closed loop, if you still got the stock one installed and connected just enable it.
Using a wideband is ofc better so switch to that if you can.
Unless your tuner spent many hours doing part throttle tuning running the car in open loop is a very bad idea.
I don't know much about the tune. From driving it though it just sucks when it's cold and burns/wastes a lot more fuel than before over 100miles worth per tank.
s2konroids
01-03-2008 10:21 PM
