rev limiter?
The data here is for an '01:
RPM rev over limit is set at 9,200 RPM and is controlled by the ECU.
VTEC is controlled by a solenoid which will not open above 6,400 RPM unless certain oil pressure parameters are met. The reduced viscosity of the oil allows these pressures to be met when the water temp is showing ~3 bars. Actual water temp is irrelvant to the engagement of VTEC. The key is oil pressure (see your Helm manual).
There is no overlimit protection for a "high" downshift. This is where most damage (ii.e. bent valve stems) occurs.
Utah
Utah
Originally Posted by jimi,Mar 7 2006, 08:13 PM
Check your oil frequently.Keep it on the high end of the stick.
Utah
Utah
Although I still haven't maxed out on my RPM range yet ('05 S so 8300) I've always been assuming that when upshifting I could bounce off the 8300 RPM rev-limited point all day and no damage would occur. Is this correct or does one still need to be careful with upshifting at or near the rev limit?
Originally Posted by modifry,Mar 7 2006, 11:22 PM
Then why have I never seen a dyno plot out to 9200? Every one I see barely makes 9000.
i've had data capturing devices that showed my rev limit is around 9140-9150
Anyway, the rev limiter is there to protect your motor and as long as you don't mechanically overrev by a missed shift, you could theoretically bounce off the rev limiter all day, though the high revs will cause increased wear, of course.
peltier
Dec 6, 2002 04:50 PM
