Rough Shifting after fluid change
Old 01-30-2015, 11:15 PM
Belkin623's Avatar
Default Rough Shifting after fluid change
Just changed my tranny fluid with genuine honda MTF a few days ago after I changed my clutch. It was fine and felt like normal for the past two days I've been driving it. Until tonight, on my way home, I noticed it wasn't necessarily harder to put it into gear, but it's definitely rough now. Any ideas? It might just be in my head, but I feel like it should be much smoother. It feels like there's not even any fluid in there.. Just metal rubbing on eachother. And yes, I filled the fluid when the tranny was normally level, until it starts leaking out.
Old 01-31-2015, 03:07 AM
murdocsgarage's Avatar
adjust the clutch master cylinder. It may not be completely disengaging. I'm assuming that it's probably harder to put it into gear when the car is not in motion?
Old 01-31-2015, 05:18 AM
golfman's Avatar
X2 I would look first at the CMC and if its working properly because you just changed the clutch. Since you used the correct fluid in the transmission chances are it's not that as long as you did it correctly. Pushrod adjustment, check for correct amount of fluid/ leaks(especially around CMC inside near pedal), and a fluid flush would be my first areas I would check.
Good Luck
Old 01-31-2015, 09:18 AM
Belkin623's Avatar
Thanks guys. I guess today will be another work day. I bled the CMC almost 2 months ago, so the fluid shouldn't be a problem. I'll try everything else in a bit!
Old 01-31-2015, 10:32 AM
Belkin623's Avatar
Alright. Just went down and changed it to "zero free play." Im not sure what you mean by checking the CMC. It's not leaking anywhere. The fluid is good enough to not cause problems. And I used the suggested, Genuine Homda DOT 3 Brake Fluid when I bled it. Also, it's NOT harder to put into fear when the car is stationary (and off).
Old 01-31-2015, 01:19 PM
zeroptzero's Avatar
Received 3,391 Likes on 2,462 Posts
I would leave a bit of freeplay on the clutch rod, just in case it tightens up and then you will get clutch slippage.
Check the slave cylinder rod to make sure it is sitting in the fork correctly and it is pushing it correctly when the clutch is depressed (need a helper for that )
Old 02-02-2015, 06:49 AM
Belkin623's Avatar
I can't check the slave cylinder rod without taking the big boot off.. And if I check it, I can't put the boot back on without messing with it. I doubt that's the problem though.. The clutch and all its linkage seems completely fine. The shifting is only rough when the car is in motion.
stwokayyy
04-15-2020 11:21 PM
shift957
07-07-2016 11:19 AM
s2k tony
07-20-2015 01:35 PM
Frez2k
10-08-2010 08:25 AM
ken reich
10-17-2004 08:40 PM
Quick Reply: Rough Shifting after fluid change
