s2000 shaking.. help?
Old Dec 31, 2011 | 12:11 PM
cesarortiz's Avatar
Default s2000 shaking.. help?
i have a 07 s only mods are pwjdm intake hondata flashpro invidia dual exhuast and hfc.
i have been noticing that when i punch it ass in full throttle my car starts to shake once i pass 4500 rpm it shakes.
it runs perfectly just at full throttle it shakes like when i change gear and full throttle again it shakes like a vibration..
does anyone have an idea what it can be or if you are having the same proplem. umm my tires are balanced i have enkeis rpf1 17x9
idk anything will help
thanx.....
Old Dec 31, 2011 | 12:41 PM
LesterJ's Avatar
alignment or broken belt in a tire maybe....
Old Dec 31, 2011 | 12:57 PM
s2kx7's Avatar
by shake where do you feel the shake coming from. I have a similar issue but it causes my driver side mirror to vibrate after about 4000 rpm and accelerating. passenger side mirror doesn't vibrate at all it comes from the driver side axle. my awesome mechanic from this site said it most likely needs an axle bucket swap to cure the vibration. this is the link from someone that did it on this site.
https://www.s2ki.com/s2000/topic/720...-abs-light-on/
good luck bro
Old Dec 31, 2011 | 02:31 PM
cesarortiz's Avatar
i kinda get the feel of the vibration from the motor like if it was a mount or something
Old Dec 31, 2011 | 03:43 PM
rosodigital's Avatar
I get a vibration from the rear at high speed or getting up to high speed heavy on throttle. I know its coming from the rear of the car tho... thats about it.
Old Dec 31, 2011 | 05:23 PM
steven975's Avatar
I had that symptom before too (shaking when on heavy throttle...or any throttle between 55-75).
The problem was the inner cv joint on the driver's side was pitted. Swapping left to right fixed it...though it is 3+ hours of work.
Many S2Ks do this at 70-80K miles.
Old Jan 2, 2012 | 07:42 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
There's your answer.
I have seen it as low as 39k miles. Swapping buckets left to right is the best and cheapest fix. win win.
cesarortiz
Jan 15, 2012 05:53 PM
spo001
Jun 8, 2011 11:55 AM
rlind
May 6, 2010 03:05 AM
iamthestig
Nov 17, 2009 10:22 AM
bkmagby
May 30, 2007 06:38 AM
