Soft top stops going down
Old Sep 4, 2010 | 06:31 PM
zherbo's Avatar
Default Soft top stops going down
Soft top on my 2002 goes down most of the way stops and then i here a pop and it goes on down, lubed a pivit points, looked at the motor drive gears and see to problem there, any ideas would that would help.
Old Sep 4, 2010 | 06:54 PM
idea-catalyst's Avatar
Search for Modifry's strap kit - replaces the elastic straps that cause the top to fold correctly.
Old Sep 6, 2010 | 07:38 AM
SgtB's Avatar
You can also push the bar back as the top goes back. Look at the little bar in the middle of the top that can be moved freely by hand when the top is loose. That bar needs to be pushed to the rear of the car for the top to open properly. You will also notice the top goes down farther when it's back.
Old Sep 6, 2010 | 03:17 PM
zherbo's Avatar
Thanks i will try that car is not used much and top in grat condtion for age, seems like it does stay forward on the way down, top does not sit high when its down, but i guess it might be the elastic straps.
Old Sep 7, 2010 | 11:47 AM
Croc's Avatar
this is what worked for me and was clear indication that new straps are needed......
Mexs2k
Jan 20, 2022 04:22 PM
Nemui
Aug 15, 2016 11:13 AM
S2What
Mar 20, 2013 05:22 PM
amped_imports
Aug 22, 2012 12:19 PM
Riviera
Jun 16, 2009 04:31 PM
