starter motor
Old Jan 9, 2008 | 10:30 AM
truekakaka's Avatar
Default starter motor
i've been experiencing the starter grind on cold morning starts and am thinking of replacing the starter...has anyone here previously done this and if so how much did it cost you? i know several people have the same problem and would like to know if they solved it w/o replacing the starter.
is greasing the starter teeth a difficult job and am i better off buying a new starter?
majestic honda has starters for like 845$ but some other sites advertise aftermarket starters for 1/4 the price but i'm worried about durability
any input would be appreciated!
Old Jan 9, 2008 | 01:49 PM
slalom44's Avatar
Top Answer: 1
I know that somebody previously posted the idea of greasing the "starter teeth", or pinion gear on the starter, but I do not recommend this. Besides - that wouldn't do anything. If you knew how a starter works, you'd know why I say this.
It's possible that oiling (not greasing) the starter bendix will make it operate more smoothly, but you have to question why it would need to be lubed. If the shaft is slightly bent or the bendix is damaged, then a little lubrication might help. If the Solenoid isn't getting enough juice or is sticking, then lubricating the bendix probably won't do any good. If the teeth on the pinion and/or flywheel are damaged, all the grease in the world won't help. Your best bet would be to remove the starter and see what you find.
Unfortunately, it isn't easy to remove the starter. I don't have first hand experience on an S2000 but if you search around, you will find plenty of people cussing out the top bolt on the starter.
Before you do this, you may want to try cleaning the electrical contacts to the starter. That might fix your problem. If the solenoid isn't getting a strong current, that could prevent the bendix from throwing the pinion gear out to catch the flywheel.
Old Jan 9, 2008 | 05:33 PM
jyeung528's Avatar
greasing the starter teeth was recommende by billman.
Old Jan 11, 2008 | 01:14 AM
iam7head's Avatar
i dont know tho, if i am going to spent 3 hours to take that sob off, i rather just swap it with a new one.
the cost for labor and time overweight the "potential" saving
Old Jan 11, 2008 | 02:36 AM
jzz30's Avatar
if you have the starter rebuilt then it should cost no more than 200 bucks.
Old Jan 11, 2008 | 11:17 AM
jyeung528's Avatar
a few people mentioned that they replaced the starter and the noise did not go away.
Old Jan 11, 2008 | 12:01 PM
jzz30's Avatar
did those people buy a "rebuilt" starter? sometimes rebuilt starters bought over the counter arent fixed properly.
Old Jan 11, 2008 | 02:06 PM
jyeung528's Avatar
i don't recall, but i believe they bought new starters.
s2000_f20
Dec 20, 2018 01:03 AM
s2konroids
Jul 14, 2012 09:30 AM
Simoted
Oct 4, 2008 12:02 AM
truekakaka
Dec 31, 2007 04:15 PM
Scot
Aug 23, 2004 09:03 AM
