throttle cable adjustment
Old Jul 31, 2005 | 05:19 PM
steven975's Avatar
Default throttle cable adjustment
I was checking things under the hood today and I noticed the throttle cable was pretty loose. It was so loose I could amost pull it off the throttle wheel.
I adjusted it to where it had probably 2mm deflection. It was close to 10mm earlier.
my car only has 17K. Are the cables supposed to be loose?
Old Jul 31, 2005 | 05:25 PM
jlucas's Avatar
Should be no tension at closed throttle. Sounds like you've adjusted it correctly. To tight and you'll just stretch it.
Old Jul 31, 2005 | 06:44 PM
oakfloor's Avatar
Speaking of throttle cables, has anyone had one break?
Old Jul 31, 2005 | 06:48 PM
koala's Avatar
I broke one on my old RSX, but that was due to being a moron. Not from regular usage
2mm of deflection is about optimal. They have a ton of slack from the factory to prevent certain types of drivers from ramming into the car in front of them.
Old Jul 31, 2005 | 07:57 PM
steven975's Avatar
thanks.
it's adjusted so that there is low deflection and no movement of the wheel so as not to interfere with the idle.
it is more responsive now, too.
Old Jul 31, 2005 | 09:38 PM
xviper's Avatar
By the "book", the cable should have 4mm to 6mm of movement up and down at the middle of the exposed part beside the throttle body.
Old Aug 1, 2005 | 03:48 AM
bobbyb's Avatar
Talking
it seems miatas are set up the same way from the factory with plenty of play in the cable for the above reasons .first thing i did to both cars was to adjust .also after a period of time it may need to be adjusted again as cable may expand.
very similar to mountain bike cable setups and adjustments .
Old Aug 1, 2005 | 09:51 AM
steven975's Avatar
The car does feel much better. It is MUCH more sensitive now. I can understand why there is more play stock as to prevent people from rear-ending someone at a light for example.
BTW, idle is fine, so I'll leave it as is.
question: could this hamper HP as the throttle would not open all the way with a lot of play?
Old Aug 1, 2005 | 10:12 AM
RACER's Avatar
The way to find out, is to have someone sit inside the car and press the accelerator pedal all the way to the floor while you look at the throttle linkage and see if it open's all the way.
It should open all the way. Even if it didn't open all the way, it may or may not have a noticable affect on overall horsepower.
Old Jun 4, 2020 | 08:41 PM
mrgizmo04's Avatar
Hopefully this is helpful to someone, on how to do it the right way:
Qs2k
Jun 4, 2020 08:40 PM
2Scars
Aug 20, 2015 08:21 PM
Squeezer
May 30, 2009 02:11 AM
6sigma
Aug 1, 2003 09:57 PM
AngrySalamander
Jun 20, 2002 12:47 AM
