Top Not Going Down
Old Jan 27, 2011 | 10:48 AM
StormTroopinAP2's Avatar
Default Top Not Going Down
Hey everyone, my top will no longer go down and my hazard light button doesnt light up anymore but the hazards lights themselves do work when I press the button. I took out the center console to regrease my shifter and unplugged both to do so. I had my top down while working on it but when I plugged in the two again the top wouldnt go back up. So I took it apart and unplugged then plugged in the top switch again and it went up. Then a few days later I go to put the top down and nothing Dont think it could be a fuse could it?
Old Jan 27, 2011 | 10:52 AM
flyingtoaster's Avatar
Maybe you tugged some of the wires off their terminals in the harness plugs.
Old Jan 27, 2011 | 10:55 AM
Pretty sure I checked that but Ill double check. It supposed to be pretty nice here today, wanna go top down
Old Jan 27, 2011 | 11:04 AM
starchland's Avatar
could be a fuse, but you didnt knock anything around the hand brake switch?
Old Jan 27, 2011 | 12:07 PM
Think I may have fixed it. Took off the console and noticed the wire that goes from my HU to my ipod was chilling around the hand brake switch. Think it was resting on it, causing the car to think the brake was never engaged. Thanks for the suggestions and quick replies
Old Jan 27, 2011 | 05:09 PM
zeroptzero's Avatar
mine did that after I had a head unit installed by a shop, turned out the little prongs under the handbrake switch weren't making proper contact. After straightening out the prongs it worked fine so they were making proper contact on the switch.
Old Jan 28, 2011 | 02:32 AM
NFRs2000NYC's Avatar
If it works and then doesnt work...then works again, it's not a fuse. If it just plain doesn't work, check the fuses.
Old Jan 28, 2011 | 11:53 AM
Croc's Avatar
another thing possible after center console removal - there are 3 switches and sockets on 2 of them are identical. if you mess up their connectors both doesn't work.
S2K9grand
Jan 22, 2013 06:20 PM
tntrac
Sep 6, 2010 10:25 AM
GyozA
Jul 29, 2007 10:33 AM
Nhan
Nov 20, 2005 06:29 PM
FooF
Jun 9, 2004 02:52 AM
