tps problem....
Old Dec 18, 2009 | 01:37 PM
whiskeybill8's Avatar
Default tps problem....
o.k. just got back from autozone and the ran my cel code and it came back
P0122 0 - 7 ----Throttle Position Circuit Low Input. The light came up last night and the engine doesn't sound normal. The guy said that it could be the sensor or could just be a corroded wire. I was wondering if this is an easy fix for me to do or should I leave it up to honda? autozone has one but its not oem and the also had a edlebrock one that's not street legeal. I don't really understan stuff like this(I know cars but don't know anything about sensors or electrical) any info would be great. I'm probally setting up an appointment tommarow with honda unless i find out it's an easy fix.
2000 s2000 NFR 35,000 miles owned for two years bought it with 27,000 miles on it and this is the first problem i've ever had.
Old Dec 18, 2009 | 05:02 PM
Skatethesea's Avatar
Not sure on this one. Never dealt with it myself. I know some Mods might chime in with good info. GL.
Old Dec 20, 2009 | 09:23 AM
AMS MIKE's Avatar
the TPS (Throttle Position Sensor) is on the side of your T/B (Throttle Body)
Unplug the connector and make sure pins are good and not bent and no corrosiaon or anything of that sort....
about 2" away from the TPS connector, strip the MIDDLE "red/black" wire like 1-2mm so you can see bare wire. becarefule and do NOT cut the wire.
get a multimeter.
put the key in ignition and 2-click. Do NOT start car
get out your multimeter and place POSITIVE lead onto the "red/black" stripped wire. place the NEGATIVE lead on a good grounding spot in the engine bay.
you should read about .3V
leave the multimeter leads on ground and on the "red/black" wire. NOW move the throttle cable on the T/B to WOT (wide Open Throttle 100%)
you should now read 4.8V
if your readings are way off, this is why you have the Code 7. You will need to loosen the sheered off bolts on the TPS and rotate it so it reads .3V at 0% throttle and 4.8V at 100% throttle. If you do this, best thing is to slot the bolts and use a screw driver to remove, THEN replace them with allens or torx bit screws.
*****when done, put electrical tape around the bare wire*****
Hope this helps!
Old Dec 20, 2009 | 11:44 AM
Broken2G's Avatar
I tried this myself today, with the TPS to the most extreme setting the highest voltage i can get WOT is 4.40. Am I in need of a new sensor as well?
Old Dec 20, 2009 | 01:36 PM
AMS MIKE's Avatar
You need to adjust it.
See my post above
Old Dec 20, 2009 | 02:03 PM
Broken2G's Avatar
I tried to adjust it, I could get the voltage to go down to 3.0 wot but no higher than 4.40
rivasd64
Apr 26, 2017 10:19 AM
AP2_s2000
Jan 23, 2017 04:19 PM
Bigmanslim
May 20, 2010 02:54 PM
Gant
Jan 14, 2005 05:35 PM
