Trans issues
Old May 14, 2009 | 06:34 PM
s2000isu's Avatar
Default Trans issues
So I just installed a 00 trans in my 01 and I am having some issues. It shifts in every gear perfect but it has to be in just the right spot to get it to go in 5th. If I move the shifter all the way to the right and push up it wont go into 5th but if i move it a 8th inch over it goes in no problem. I installed the shifter from my 01 trans because the boot on the the 00 shifter was torn. Does anyone know if theyre different shifters or is there and easy fix? Thanks
Old May 15, 2009 | 03:48 AM
Bugs2k's Avatar
same shifter on both cars. does your shifter feel a little loose. if so there is a bushing that goes around shifter ball where it moves in trans. check to see if you left in your old trans. it is called a cover pivot.
part #54111-S2A-003
you can buy it here. #8 in diagram. hope this helps.
http://hondapartsunlimited.com/schonda/jsp...&hidIrno=%7C008
Old May 15, 2009 | 12:23 PM
s2000isu's Avatar
Thanks bugs the shifter feels fine and I did check the old trans to see if it fell off but it doesnt seem to have im gonna go pull the shifter now.
Old May 15, 2009 | 01:18 PM
Bugs2k's Avatar
ok
sg611
Jul 6, 2019 12:20 PM
samson123
Nov 3, 2017 09:00 AM
chenpo
Mar 6, 2011 12:00 PM
s2kjb
Aug 5, 2008 05:47 AM
gti2000
Aug 7, 2007 02:55 PM
