UTH changes on the 06 S2000
Old Feb 18, 2006 | 10:37 AM
  #71
2QYK4U's Avatar
Originally Posted by MoreCowbell,Feb 18 2006, 12:33 PM
that new air/fuel ratio sensor they talked about above that replaces an upstream o2 sensor would that be located on the header?
I couldn't tell you...but if the issue comes up during the install I'll be sure to let you know.
Old Feb 19, 2006 | 01:41 AM
  #72
WayneTeK's Avatar
yeah bro.. keep us updated!
Old Feb 19, 2006 | 06:35 AM
  #73
Yflyer's Avatar
Originally Posted by MoreCowbell,Feb 18 2006, 11:33 AM
thanks for the info on the exhaust.
Hope the install of your header goes smoothly.
The A/F sensor looks like it is in the same place as the upstream O2 sensor. Helm describes both as zirconia sensors, so I can't really say what the difference, i.e how it works, is btween an O2 sensor and an A/F sensor
Old Feb 19, 2006 | 07:06 AM
  #74
2QYK4U's Avatar
BTW...when I have the Toda RH installed...should I expect to get the CEL error codes?
Old Feb 19, 2006 | 08:21 AM
  #75
DJFriar's Avatar
Anything under hood that changed, like to the hood itself? I bought a Comptech Al/Ti Strut Bar, but I can't seem to close the hood with it installed. I think there are crossmembers in the way.
Old Feb 19, 2006 | 08:40 AM
  #76
2QYK4U's Avatar
If you have the Seibon CF hood you cannot use the Comptech strut bar. I found that out the hard way. If you have the OEM hood, you should be able to use the strut bar.
Old Feb 19, 2006 | 09:27 AM
  #77
DJFriar's Avatar
I have the stock hood. Any ideas what else I could be hitting?
Old Feb 19, 2006 | 10:07 AM
  #78
2QYK4U's Avatar
More than likely you are hitting the under braces. Honda didn't change the hood itself; not sure if they changed the strut tower "areas" due to VSA. You might want to check the position of the strut bar itself. The bar is adjustable--simply loosen the bolt on each side of the bar and rotate the bar.
Old Feb 19, 2006 | 02:02 PM
  #79
DJFriar's Avatar
^^^ Tired that, didn't help. The strut also appears to be "resting" on part of the air intake (round tube part, looks kinda like heating duct, on the driver's side of the engine compartment).
Old Feb 19, 2006 | 02:17 PM
  #80
2QYK4U's Avatar
^ Are both strut brackets flush against the shock mounts? Did you raise the front end a little bit when installing the bar?
These are the instructions you should have followed:
http://www.comptechusa.com/store/media/ins...ions/ins116.pdf
