vafc ver 1 problem!
Old Apr 28, 2004 | 05:31 PM
2broke2drive's Avatar
Default vafc ver 1 problem!
i tried to disconnect the vafc from it's harness (the vafc is hardwired) and when i give it some gas the car wants to die. Can someone help me?
TIA
Jesse
Old Apr 28, 2004 | 06:01 PM
red02s2k's Avatar
b/c there is wire that need to be reconnected togher ill find them in a min
Old Apr 28, 2004 | 06:07 PM
oh yeah, i forgot about that! let me know which wire it is because i don't have my diahgram with me
thanks!
Old Apr 28, 2004 | 06:21 PM
AusS2000's Avatar
MAP signal is the one giving you trouble, but there's also the VTEC line to consider if you plan driving over 6000 rpm.
Old Apr 28, 2004 | 06:24 PM
red02s2k's Avatar
ok here you go vtm signal blue wire on the vafc , vtecsoleniod signal pink and purple wire on vafc and pressure signal white and yellow wire on vafc those need to be takin off and the wires on the ecu that where there need to be hooked up to each other
Old Apr 28, 2004 | 06:35 PM
thanks guys!
Old Apr 28, 2004 | 08:26 PM
red02s2k's Avatar
yep yep tell me if it works
Apex1.0
Aug 20, 2014 08:58 AM
J_STATUS
Jun 21, 2008 04:20 PM
freshs2k
Mar 5, 2007 03:29 AM
mxt_77
Sep 1, 2004 01:06 PM
gilbertg
May 31, 2003 07:42 PM
